The 6th generation of Mitsubishi TRITON (hereinafter “the car“) made its debut on 26 July 2023 at Queen SiriKit Convention Center. The car comes in three body types: Double Cab, Mega Cab, Single Cab and was designed based on “Beast Mode” design concept making the overall look of the car.
- A beefed-up body size compared to the previous model, a newly developed ladder frame that provides durability and reliability, and a newly developed engine that achieves both higher output and improved environmental performance
- A newly developed suspension that provides excellent ride comfort and steering stability, and Super Select 4WD-II system and upgraded drive modes that achieve high road performance
- A front face with a strong sense of presence and reliability, a wide and robust styling, and a classy interior offering excellent functionality and operability
- Significantly improved safety and comfort for a wide range of purposes, from business to personal use
Technical Data
The technical data (as of 26 July 2023) of the car are as follows:
- Length 5,320 mm.
- Widght 1,865 mm.
- Hight 1,795 mm.
- Wheelbase 3,130 mm.
- Ground Clearance 222 mm.
Currently, the only engine available to Thai customers is 2.4 Diesel Single Turbo Mid-Power Engine producing 184 Ps and 430 Newton Meters of Torque. However, Mitsubishi will launch more variants of powertrains at the end of 2023 including 2 more powertrains i.e. 2.4 Diesel Single Turbo Low-Power Engine producing 150 Ps and 330 Newton Meters of Torque and 2.4 Diesel Bi-Turbo High-Power Engine producing 204 Ps and 470 Newton Meters of Torque. The technical data of the powertrains are as follows:
Single Turbo Mid Power
4N16 Diesel 4 Cylinders DOHC 16 Valves 2.4 liter 2,442 CC., Bore x Stroke 86.0 x 105.1 Millimetres, Compression Ratio 15.2 : 1, Turbocharged, 184 PS at 3,500 RPM, 430 Newton Meters of Torque at 2,250 – 2,500 RPM couple with 6 Speed Automatic or Manual Transmission, RWD or 4WD Super Select 4WD ll with Active Yaw Control
Single Turbo Low Power (coming soon)
4N16 Diesel 4 Cylinders DOHC 16 Valves 2.4 liter 2,442 CC., Bore x Stroke 86.0 x 105.1 Millimetres, Compression Ratio 15.2 : 1, Turbocharged, 150 PS at 3,500 RPM, 330 Newton Meters of Torque at 1,500 – 3,000 RPM couple with 6 Speed Automatic or Manual Transmission, RWD or 4WD Super Select 4WD ll with Active Yaw Control
Bi-Turbo High Power (coming soon)
4N16 Diesel 4 Cylinders DOHC 16 Valves 2.4 liter 2,442 CC., Bore x Stroke 86.0 x 105.1 Millimetres, Compression Ratio 15.2 : 1, Turbocharged, 204 PS at 3,500 RPM, 470 Newton Meters of Torque at 1,500 – 2,750 RPM couple with 6 Speed Automatic or Manual Transmission, RWD or 4WD Super Select 4WD ll with Active Yaw Control
Steering System
Rack & Pinion with Electronic Power Steering having turning radius of 6.2 meters
Suspension
- Front: Double Wishbone Independent suspension
- Rear: Leaf Spring
Brakes
- Front: Ventilated disc brakes
- Rear: Drum brakes
Specifications of Double Cab Mitsubishi TRITON
Official Price (Thailand)
- Double Cab 2.4 PRO 6MT 2WD : 820,000 THB
- Double Cab 2.4 PRIME 6MT 2WD : 893,000 THB
- Double Cab 2.4 PRIME 6AT 2WD : 938,000 THB
- Double Cab 2.4 ULTRA 6MT 2WD : 982,000 THB
- Double Cab 2.4 PRIME 6MT 4WD : 1,016,000 THB
- Double Cab 2.4 ULTRA 6AT 2WD : 1,027,000 THB
Double Cab Plus 2.4 PRO 6MT 2WD
820,000 THB
Standard equipment are as follows:
- Multi-reflector Halogen headlights
- Halogen taillights
- Power adjustible side mirrors
- Power folding side mirrors
- LED turning signal on side mirrors
- UV-cut windshield
- Gloss-black front grille
- Chrome door handles
- Black sidesteps
- Rear bumper
- Undergard
- Tailgate locking system
- Damped tailgate
- 16 inch alloy wheels with 265/70R16 tyres
- cloth seats
- Manually adjustable front seats
- Rear center armrest with 2 cupholders
- Conventional information display
- Urethane-wrapped steering wheel
- Multi-function steering wheel
- 4 way adjustable steering wheel
- Power windows
- Central locking system
- Black interior door handles
- Urethane-wrapped gear lever
- Vanity mirror on passenger side
- Overhead sunglasses storage
- 7 interior overhead handles
- Conventional climate control
- 10-inch touchscreen head unit
- Bluetooth connectivity
- Supports Apple Car Play / Android Auto
- 4 speakers
- 2 12V power outlets
- 1 USB Type-C power outlets
- 1 USB Type-A power outlets
- Folding keys
- Anti-lock Braking System
- Electronic Brake Distribution
- Brake Assist
- Active Stability Control
- Traction Control
- HCA System
- 3 Airbags
- 2 front airbags
- 1 Knee airbag
- ISOFIX
- Rear view camera
- Emergency braking signal
- Immobilizer key
Double Cab Plus 2.4 PRIME 6MT 2WD
893,000 THB
Comparing to 2.4 PRO 6MT, this variant is 73,000 more expensive and below are the increased standard equipment
- 17 inch alloy wheels with 265/65 R17 tyres
- LED Headlights
- LED Daytime Running Lights
- LED foglights
- Front chrome strip on front grille
- LED taillights
- Sidesteps with metallic trim
- Leather seats
- Leather-wrapped steering
- Leather-wrapped gear lever
- 7 inch LCD multi information display
- Satin chrome interior door handles
- KOS Key fob
- vanity mirrors with closing lid for driver and front passenger
- leather-stitched storage lid
- Digital 1-zone climate control
- 1 USB Type-C 1 power outlet for rear passengers
- 1 USB Type-A 1 power outlet for rear passengers
- Wireless charger
Double Cab Plus 2.4 PRIME 6AT 2WD
ราคา 938,000 บาท
Comparing to 2.4 PRIME 6MT, this variant is 45,000 more expensive and below are the increased standard equipment
- 6 speed automatic transmission
Double Cab Plus 2.4 PRIME 6MT 4WD
1,016,000 THB
Comparing to 2.4 PRIME 6AT, this variant is 78,000 more expensive and below are the increased standard equipment
- Super Select 4WD II system
- Active Yaw Control
- 7 selectible drive modes
- Normal
- Eco
- Gravel
- Snow
- Mud
- Sand
- Rock
Double Cab Plus 2.4 ULTRA 6MT 2WD
982,000 THB
Comparing to 2.4 PRIME 6MT 4WD, this variant is cheaper as it lacks 4WD system. However, this variant is more loaded and below are the increased standard equipment
- 18 inch alloy wheels with 265/60R18 tyres
- Automatic headlights
- Rain Sensor
- Electronic 8 way adjustable driver seat
- Electronic Lumbar Support
- driver’s overhead handle
- Dual Zone climate control
- Wireless Apple CarPlay
- Side airbags
- Curtain Airbags
- 4 front parking sensors
- 4 rear parking sensors
- ADAS “Diamond Sense” safety package including
- Forward Collision Warning
- Auto High Beam
- Multi-around View Monitor
- Blind Spot Warning with Lane Change Assist
- Rear Cross Traffic Alert
Double Cab Plus 2.4 ULTRA 6AT 2WD
1,027,000 THB
Comparing to 2.4 ULTRA 6MT, this variant is 45,000 more expensive and below are the increased standard equipment
รวมภาพคันจริง All NEW Mitsubishi TRITON ทั้งรุ่นมาตรฐาน และรุ่นตกแต่งพิเศษ
